Creating and Using Process Watch › Start a Process from Process Watch
The Process Watch allows a content administrator to define and monitor the selected automation objects in CA Process Automation. When you create a process watch, you can add a process to it and sort by filters to monitor the process.
- Log in to the CA Process Automation web interface.
- Click the Process Watch pane in the Operations to open it.
- Right-click the process and select Start Process.
The Process instance that you started appears.
- View the Touchpoint, state, and start and end times of the process instance you started.
Copyright © 2014 CA.
