Auditing User Actions › View the Audit Trail for an Agent
With read permissions on a configuration object, you can view the associated audit trail. Viewing the audit trail for configuration objects requires CA EEM access rights that include Environment User and View Configuration Browser.
The agent audit trail monitors the following actions:
- Operator category is enabled on the Modules tab and changing a configured value.
- Agent is quarantined or not quarantined.
- Agent is locked or unlocked.
- Click the Configuration tab.
- On the Configuration Browser palette, expand the Agents node and select the target agent.
- In the Contents pane, click the Audit trails tab.
The Audit Trails tab displays the following information for all records:
- Object Name
- Last Updated
- Username
- Action Type
- Description
- (Optional) To sort the audit trails by a specific column, select Sort Ascending or Sort Descending from the target column drop-down list.
For example, to audit a specific user, select a sort option from the Username column drop-down list, and then scroll to the appropriate record.
- (Optional) To change the number of records that the product displays on a page, select a value from the Rows On Each Page drop-down list.
- Examine the records in the audit trail.
If the audit records comprise multiple pages, use the toolbar navigation buttons to display the first page, previous page, next page, or last page.
Copyright © 2014 CA.
