Administering Reports › About Reporting › Structure of Collected Data
Orchestrators collect information that is related to:
- The Configuration topology, including:
- The Domain
- The Environments in the Domain
- The touchpoints in each Environment
- The agents in the Domain that are mapped to touchpoints, proxy touchpoints, or host groups
- Automation object definitions for processes, resources, datasets, calendars, and agendas. The information includes a reference to the Orchestrator that manages the Library where the objects are defined. Examples include:
- Object types
- Object paths
- Versions
- Owner
- Keywords
- Creation and modification dates
- Run-time instance objects that the product creates while running processes. Run-time instance objects include process instances, individual operator instances that the product runs as part of process definitions or agenda evaluations (scheduling). Reported information includes:
- Operators
- References to the hosts on which instances run
- Run date and time
- Run results
- Run parameters
Copyright © 2014 CA.
