Previous Topic: JDK PrerequisitesNext Topic: CA EEM Prerequisites
Setting the Default Java Home Path
If the default version is different, change the default Java version on the shell where you will start the CA Process Automation installation.
  1. Browse to DVD1 folder
  2. Set default java on the command prompt or shell.
    Windows
    set JAVA_HOME=<home_directory_of_jdk (not_bin)>
    set PATH=%JAVA_HOME%\bin;%PATH%
    UNIX or Linux
    export JAVA_HOME=<home_directory_of_jdk (not_bin)>
    export PATH=$JAVA_HOME/bin:$PATH
  3. Start the installer from this command prompt or shell.
    Windows
    .\ Domain_Installer_windows.bat
    UNIX or Linux
    ./ Domain_Installer_unix.sh
    The installer first starts the third-party installer and then starts the Domain Orchestrator installer.
