Previous Topic: Unattended Domain Orchestrator InstallationNext Topic: Required Parameters in the response.varfile
Create a Response File
The first step in performing a silent installation of CA Process Automation is to create a response file.
Consider the following notes about the response file:
  1. Insert Disc 1 of the CA Process Automation installation media or browse to the location where you previously copied the installation files from the installation media.
  2. Open the DVD1 folder.
  3. Open the following file.
    response.varfile
  4. Provide the appropriate parameter values.
    The varfile includes parameter descriptions. For example, to enable CA EEM to use the NTLM protocol to authenticate CA Process Automation users, use the following setting:
    enableNTLM=true
    Required parameters can be found here.
  5. Save the varfile to the path that contains the silent installation script file.
    The response file is created.
