Previous Topic: Java ExampleNext Topic: Operator Ports
Resource for Running Invoke Java Operator Example
The installation process adds one resource to the User Resource folder under Repository in the Manage User Resources palette on the Configuration tab. The JAR file, MyAccount.jar, is located in the Invoke_Java_Op_Example_jars folder. You can use the MyAccount.jar file to run the Java example that is provided in the Required Main Method field of the Invoke Java operator.
Example
