Previous Topic: Introduction to OperatorsNext Topic: Where Operators Can Run
Operator Overview
Containers for operator categories are represented as folders in the Operators palette in the Designer.
CA Process Automation contains the following categories of operators:
Standard
Standard operators include essential functionality operators that control workflows in processes. Simple functionality such as starting, stopping, linking, and commenting, are provided with the Standard operators. You can also set looping and reset options, and incorporate the lane changes using these operators.
Catalyst
Catalyst operators support the UCF create, read, update, delete (CRUD), and event subscription interfaces. These operators expose Unified Service Model (USM) object types and properties.
Command Execution
Command Execution operators run processes and scripts on the host operating environment.
Databases
Databases operators provide an avenue to communicate and run database queries against different database servers.
Date-Time
Date-Time operators manage the date and time for the CA Process Automation server.
Directory Services
Directory Services operators support the Lightweight Directory Access Protocol. All of these operators work with different LDAP servers except for operators specific to the Active Directory.
Email
Email operators automate tasks that are performed on emails and folders in an email server. Email operators read emails from the mail server through IMAP/POP3.
File Management
File Management operators monitor directories, files, and their contents. File Management operators can be run either locally or on a remote system. These operators create, delete, rename, compress and uncompress local files, and watch files on the touchpoint where the File Management category is running.
File Transfer
File Transfer operators let you use FTP and SFTP.
Java Management
Java Management operators provide a management interface for systems that support JMX.
Network Utilities
Network Utilities operators allow the user to communicate to other network devices through SNMP.
Process Control
Process Control operators run, monitor, and control CA Process Automation processes.
Utilities
Utilities operators invoke external JARS in CA Process Automation.
Web Services
Web Services operators provide various standard network protocol utilities to the automated business processes made possible by CA Process Automation.
