Previous Topic: nowNext Topic: resetResource
parseDate
The parseDate function returns a date object after parsing the specified string in the required format.
Syntax
dtDate = parseDate(dateStr, format)
Arguments
dateStr (String)
Specifies the string that needs to be parsed as a date.
format (String)
Specifies the format required to interpret the date string provided; for example: MM/dd/yyyy.
Return Value
dtDate (Date)
Date equivalent of input dateStr String as parsed using the input format String.
Examples
  1. Sets dtDate to a value of Dec 10, 2009 12:00:00 AM, when the format is MM/dd/yyyy.
    dtDate = parseDate('12/10/2009','MM/dd/yyyy')
  2. Sets dtDate to a value of Oct12, 2009 12:00:00 AM, when the format is dd/MM/yyyy
    dtDate = parseDate('12/10/2009','dd/MM/yyyy')
  3. Fails the following input because the input date string does not match the input format.
    dtDate = parseDate('12-10-/2009','dd/MM/yyyy')
