Resources › Monitor and Edit Resources
You can monitor and edit the resources in a Resource object on the Operations page. The Operations page allows you to modify the current version of a Resource object. Your changes are automatically applied to any Manage Resource operators using the Resource object.
- Click the Operations tab.
- In the Links pane:
- Expand Process Watch or Resources.
- Expand the list of folders or search for a specific process watch or resource object.
- Select a resource object.
The current version of the Resource object appears.
- Select a resource and then make any of the following changes.
- In the toolbar, click Lock to lock the resource. Click Unlock to unlock a resource. You can also click the lock icon in the State column to toggle this setting.
- Click Clear to release any used resources and reset free resources to the maximum amount available.
- Click the Amount, Used, and Description fields to edit their values.
- Click Refresh to view the latest system data.
Your changes are available to Manage Resource operators.
- To add or edit resources in a Manage Resource operator in a Schedule:
- Expand Links and click Active or Global Schedules.
- In the list of schedules, double-click a schedule.
- In a Manage Resources item of the schedule, click Properties.
- Click the Specific tab.
- Click Check Out.
- Click Add, Edit, or Delete to configure the resources.
- Click Check In or click Save and Close.
Copyright © 2014 CA.
