Previous Topic: Apply XSLT OperatorNext Topic: Output Parameters
Input Parameters
Input XML Source
Defines the source XML document to transform to one of the following formats:
Expression
Defines a pattern for identifying a string of values. For example, you can define the expression Datasets[“/VER2_Dataset”].srcXML
XML File Path
Defines the path of a file where an operator is executed. The file path can be a shared location or a URL.
Consider the following examples:
  • File path: c:\sourcefiles\books.xml
  • Shared location: \\fileserver\sourcefiles\books.xml
  • URL: http://fileserver:8080/sourcefiles/books.xml
Inline XML
Specifies the XML data that acts as an input.
Input XSLT Source
Specifies the source XSLT information in one of the following formats:
Expression
XSL File Path
  • File path: c:\sourcefiles\books.xsl
  • Shared location: \\fileserver\sourcefiles\books.xsl
  • URL: http://fileserver:8080/sourcefiles/books.xsl
Inline XSL
Specifies the XSL data that acts as an input.
XSLT Version
Specifies one of the following options to determine the XSLT version that is used to transform the source XML:
Input Parameters
Specifies the input parameters as key-value pairs in XSLT Operator. You can dynamically assign values to the input parameters (key) that are defined in XSL.
You can define a key (top-author) in XSL and can assign a value (Robert Kisosk) from an XSLT Operator as in the following example:
<xsl:param name="top-author">Jasper Forde</xsl:param>
Key: top-author Value=”Robert Kisosk”
