Previous Topic: TimestampNext Topic: Keystore Parameters
Username Token
Add Username Token
Adds a Username Token to the <wsse:Security> header and enables all of the Username Token parameters.
Username Token Parameters
Includes the following values:
User Name
Defines the value of the Username token.
Password
Defines the password that is associated with the Username Token.
Password Type
Specifies the type of password.
Values:
  • 0: The product delivers the password in clear text.
  • 1: The product delivers the password in digest form (the password is encrypted and not delivered in clear text).
  • 2: The product delivers no password.
Add Nonce?
If selected, the product adds a nonce element (such as a hash value) to the Username Token. The web service may not require this element.
Add Created?
If selected, the product adds a Created element that indicates when the Username Token was created. The web service may not require this element.
Note: If you set the Password Type to Digest, the product automatically adds the Nonce and the Created elements to the Username Token.
