Previous Topic: HTTP Put OperatorNext Topic: Output Parameters
Input Parameters
HTTP URL Information
See HTTP URL Information for descriptions of input parameters.
HTTP Put Information
HTTP Put Information specifies the body of the HTTP request
Is Chunked?
Specifies whether to send the HTTP request chunked.
When chunk coding is set, the HTTP request does not contain the "content-length" header.
Note: HTTP 1.0 does not support chunk coding. The HTTP Put operator fails with an 'HTTP client protocol error' if chunk coding is set and the HTTP version is 1.0.
Values
  • True - Indicates to send the HTTP request chunked.
  • False - Indicates that the HTTP request is not to be sent chunked.
  • Any other value - Same as False.
Default
Blank - Same as False.
Content Type
Specifies the type of the content that composes the HTTP request body, which is set as a header (content-type) in the HTTP request.
Values
This value is one of the following:
  • A value selected from the drop-down list of different media types.
  • Blank, where the content is retrieved from a file specified in ‘Content File Path.’
    CA Process Automation sets the value to application/octet-stream. The HTTP server is then responsible for interpreting this generic content-type.
  • Blank, where content is retrieved from the ‘Content’ field.
    CA Process Automation does not set the content-type. The HTTP server is then responsible for interpreting the no content-type header.
  • A valid media type that you manually enter into the field.
    For valid media types, see the IANA website pages on assignments/media-types.
Note: Ensure that you set the right content-type, especially when the content is not retrieved from a file.
Content Character Encoding
Specifies the character encoding of the content of the HTTP request body. Set this field only if the content type is all characters, for example: ‘text/XXX’.
Values
  • A value selected from the drop-down list of different character sets (encodings).
  • A valid character set (encoding) that you manually enter into the field.
    You can find valid encodings on the IANA website pages on assignments/character-sets.
Note: Ensure that you set the right character encoding, especially when the content is not retrieved from a file.
Retrieve Content From File?
Specifies whether to retrieve the HTTP request body from a local file on the host where the touchpoint is running.
Values
  • Selected - Indicates to retrieve the HTTP request body from a local file on the host where the touchpoint is running.
  • Cleared - Indicates to retrieve the HTTP request body from the Content field.
Content File Path
Specifies the path to a local file on the host where the touchpoint is running. The local file contains the HTTP request body.
Content
Specifies the HTTP request body.
HTTP Proxy Information
See HTTP Proxy Information for descriptions of input parameters.
HTTP Headers Information
See HTTP Headers Information for descriptions of input parameters.
HTTP Cookies Information
See HTTP Cookies Information for descriptions of input parameters.
HTTP Response Content Information
See HTTP Response Content Information for descriptions of input parameters.
HTTP Configuration Information
See HTTP Configuration Information for descriptions of input parameters.
