Previous Topic: existsInteractionRequestFormNext Topic: existsProcessWatch
existsProcess
The existsProcess function checks whether a process object exists in the given path. The path can be an absolute/relative path. The relative path is relative to the process in which the script is executed.
Syntax
bExists = existsProcess(processPath)
Arguments
processPath (String)
Specifies the full/relative path of the process object whose existence needs to be checked.
Return Value
bExists (Boolean)
Returns true if the process object exists or false if it does not.
Example
if (existsProcess(processPath))
	Process.mseg_process= "\'Pass control to previous oper.\' exists" ;
else
	Process.mseg_process= "\'Pass control to previous oper.\' does not exist" ;
