Previous Topic: convertJsonNext Topic: convertXml
convertValueToXml
The convertValueToXml function returns an XML fragment based on an array of simple types or a ValueMap of simple types.
When using a ValueMap, the XML elements are created using field names as tags and field values as the contents. You can specify a string or null for the tag parameter when using ValueMaps. If you specify a string, the string is used to create a root element with the specified tag. The elements that were created from the ValueMap are contained within that root element. If you specify null, the elements are at the root level.
When using an array, specify a string for the tag parameter. That string is used to create the element tags with the array values as the element contents.
Syntax
sXML = convertValueToXml(arrayOrVmap, tag)
Arguments
arrayOrVmap (String)
Specifies an array or ValueMap.
tag (String)
Specifies the mandatory tag to use with an array or the optional tag to use with a ValueMap.
Return Value
sXML (String)
The return type is String.
Examples
  1. In this example, Process.array contains values 1, 2, and 3.
    Process.xml = convertValueToXml(Process.array, "test")
    Process.xml contains the following XML fragment:
     <test>1<test><test>2<test><test>3<test>
  2. In this example, Process.valuemap has two fields with the names "field1" and "field2" and values "value1" and "value2".
    Process.xml = convertValueToXml(Process.valuemap, null)
     <field1>value1</field1><field2>value2</field2>
