Previous Topic: Disable Operators or Deactivate BranchesNext Topic: Reset Operators in a Process
Abort an Operator
The Abort Operators command aborts processing of one or more selected operators that are in a Running state. An aborted operator enters a Failed state. Processing does not continue on an aborted branch of a process, but you can still continue on other branches. If you defined an exception handler, it is executed to handle an abort exception.
  1. Open a running instance of a process.
  2. Select the running operator that you want to abort.
  3. Click the Abort Operators button on the Process Designer toolbar:
    Processing for the operator is aborted.
