Previous Topic: Suspend a ProcessNext Topic: Set and Remove Breakpoints in a Process
Change whether Processes are Unloaded on Completion
When running a process in debug mode, the Workflow module typically does not unload the process instance when it reaches a Stop operator. This allows you to modify and restart the process.
To force the Workflow module to unload a process when it reaches a Stop operator, click Keep State on the Control menu to clear the check mark next to the command. You can also use the Switch Process Status on Completion button on the toolbar to switch this command on or off. The toolbar button remains inactive while the command is toggled on.
