Previous Topic: Specify an Archival PolicyNext Topic: Specify ROI Properties
Specify the Folder Release
A content designer can provide release information for a folder. The Release tab in the folder properties provides the release version of the folder. Specifying the release version for a folder is required to export the folder as a content package. Adding information that describes the folder content can help the content package consumer when the content is imported to a new environment.
  1. Click the Library tab.
  2. Right-click the folder on the right pane of the Library, and then select Properties.
  3. On the Properties pane, click the Release tab to display the folder properties.
  4. Click the ReleaseVersion attribute Value field.
  5. On the Value window, enter the folder Release Version, and then click OK.
    Note: You cannot delete or edit the ReleaseVersion attribute, but you can insert the appropriate release version in the Value column.
  6. Click Save.
  7. Click Add Property or Remove Property to define or remove more folder properties.
    For example, you can add the following information in the Release tab:
