Adds new options to the Select field with a simple set of values that you define in code.
Specifies the unique identifier of a Select field.
Specifies an array of objects where each object has two properties ("name" and "value") that are necessary to represent the Select field options. The "name" property for each object is represented as the key for the option added and "value" property would be the value. If you have an array of names and values, then you could also use the ca_pam_createSelectStore function to create the "values" object (as shown in the example).
None.
This example uses the user selection of West or North in a separate Region field to update icons available in the City field dynamically.
if('West'==regionChoice)
var cityOptionNames =["New York","Rio De Janeiro","Mexico City"]
var cityOptionValues =["West_01","West_02","West_03"];
if('North'==regionChoice)
var cityOptionNames =["Madrid","Moscow","Copenhagen"]
var cityOptionValues =["North_04","North_05","North_06"];
ca_pam_addValuesInSelectStore('Form1.City', ca_pam_createSelectStore(cityOptionNames ,cityOptionValues ))
You can also find this function in the out-of-the-box content in CA Process Automation.
Copyright © 2014 CA.
