Previous Topic: Configure and Publish a Custom Operator GroupNext Topic: Custom Operator: Custom Panels Tab
Edit a Custom Operator Group Configuration
Administrators can edit a custom operator group configuration. Republishing does not update all changes that you make in the Modules tab of the Configuration Browser. If a group you edit was already published at least once or another user is using it, CA Process Automation only publishes parameters new to the group. The delete or change of data type operations on variables that were already published are not updated at the Domain or environment level when you republish. However, CA Process Automation does save the changes at the custom operator level. You can view the changed data type variables when you open the custom operator in a group.
  1. To open the custom operator editor, double-click a custom operator on the Library tab.
  2. Click the Group Configuration tab.
  3. Click Lock to lock the group.
    CA Process Automation enables the Add Variable and Add Page options.
  4. Add, delete, or edit variables or pages as appropriate.
  5. Click Save Configuration.
  6. Click Unlock.
    When you use a custom operator in the edited group in the Designer tab, verify that the custom operator includes all of your group changes (including data type changes).
