Previous Topic: Copy and Paste an Object or a FolderNext Topic: How to Work with Nonmodifiable Content
Cut and Paste an Object or a Folder
You can cut objects or folders and then paste them to the same or a different folder. For example, you can cut a custom operator object and then paste it within the same library.
  1. Click the Library tab.
  2. Identify the objects to cut in the main window.
  3. Select one or more source objects or folders and click Cut.
  4. In the Library Browser folder pane, click the destination folder in the same automation library and click Paste.
    If the names of the objects to paste exist at the target location, select objects at the target location to replace with the objects you cut.
