Previous Topic: Object Properties: Group ConfigurationNext Topic: Object Properties: Version Tab
Object Properties: Preview Tab (Calendar)
The Preview tab lets you view the calendar dates you defined on the Basic tab or the on the Advanced tab.
Included Dates
Displays all the dates included in your calendar rule settings.
Preview Exclusion Calendar
Displays exceptions to rules.
Delta
Specifies the number of days an eligible date is shifted when it falls on an omitted or excluded date. A negative Delta value shifts forward (earlier), and a positive value shifts backward (later). When this value is zero (the default), the eligible date, normally included in the calendar rule, is marked in bold red and omitted.
Max Shift
Defines the maximum number of shifts or adjustments to allow if repeated shifts fall on closed days.
