Previous Topic: Add TouchpointNext Topic: Bulk Touchpoint Removal
Bulk Agent Removal
The Bulk Agent Removal dialog appears when you lock the Domain, right-click the Domain and select Bulk Agent Removal. Administrators specify search criteria that includes the agents that are candidates for removal. From the search results, administrators indicate the agents to remove and then click the Delete button.
Note: Removing the agent reference does not uninstall the agent from the host.
Search Request
Contains controls for defining the search request. Select one of the radio buttons and optionally enter a search expression.
Search by IP address pattern (radio button)
Indicates that the specified Search expression is an IP address pattern. For example, 10.131.91.0/24.
Search by host name pattern (radio button)
Indicates that the specified Search expression is a host name pattern.
Search Expression
Defines an expression that includes all agents that you want to remove. Leave the field blank to return all agents
Agent Results
Lists all agents that match the search criteria.
Select the agents to delete.
Lists the search results by Agent Name, Agent Host Name, IP Address and Status, where each row is preceded by a check box.
Selected - Remove this agent reference from the CA Process Automation Domain. Only agents in inactive status are eligible for bulk agent removal.
Cleared - Do not include this agent in the bulk agent removal.
