Previous Topic: Orchestrator ResourcesNext Topic: Operations Tab
User Resource
You can add scripts to the User Resources folder in the global Repository. Orchestrators and agents can invoke user resources by reference.
The following fields appear on the Add New Resource: "Untitled" page for User Resource:
Resource Name
Specifies how the resource is labeled, where the label can be a file name such as buildscript.js
Resource Subfolders Path
Specifies the path to the resource from the current folder, for example, /Windows Scripts.
Resource File
Specifies the file with its path.
Module Name
Specifies the name of the module.
Resource Description
Specifies a description that is visible to users.
