Previous Topic: Object Properties: Tags TabNext Topic: Designer Tab
Object Properties: Versions Tab
The Versions tab contains the following fields:
Version
Specifies the versions of the selected automation object.
Release Version
Identifies the specific version of an object that was imported, or that you want to export, then import, to a production environment. You can set this identifier on any individual object.
The product locks this field in the following circumstances:
Current
Specifies whether this version is the current version.
Baseline
Specifies whether this object was saved as a baseline. A baseline object can be used but cannot be edited. For example, you can save a package as a baseline before you export it.
Last Modified On
Specifies when the object was last modified.
Modified By
Specifies the User ID of the last user who modified this object.
Created On
Specifies when the object was created.
Created By
Specifies the user ID of the user who created this object.
