The audit trails on the Configuration tab display audited actions for the selected node in the Domain hierarchy. Audit trails are sorted by user ID and time and are available for the following nodes:
The following descriptions are for read-only columns:
Displays the name of the selected node (for example, Domain, environment, Orchestrator, or agent).
Displays the date and time at which the node was last updated.
Displays the user ID of the user that started the action.
Displays the type of action (for example, Added, Changed, Deleted, Moved, Enabled, Locked, or Renamed).
Displays a description of the action, including the new values of changed properties.
Copyright © 2014 CA.
