The Databases operator category configuration specifies default property settings for Databases operators of the following database types:
Note: For details about configuring default property settings, see "Configure Databases" in the Content Administrator Guide. For operator-level details, see the Content Designer Reference.
Specifies the database properties when an instance of an Oracle database server hosts one or more CA Process Automation databases.
Specifies the default type of Oracle JDBC driver.
Note: Use a JDBC version that matches the version of the Java Development Kit.
Values: This property can have one of the following values:
Default: thin
Specifies the value oracle.jdbc.OracleDriver as the default driver.
Specifies the host where the Oracle database is running.
Specifies the default port for the Oracle database.
Specifies the default user name for the Oracle database user.
Specifies the password that is associated with the specified Default UserName.
Specifies the Oracle Service ID.
Specifies the source of the contents of tnsnames.ora in the Oracle directory. The Oracle TNS Names file translates a local database alias to information that enables connectivity to the database. This information includes information such as the IP address, the port, and the database Service ID.
Specifies the default maximum rows to retrieve.
Values: This value can be one of the following:
10 to 512
Default: 10
Specifies one of the data encryption methods that Oracle supports, where RCA_128 and RCA_256 are for domestic editions only.
Specifies checksums that Oracle supports. See your Oracle documentation.
Default: MD5
Specifies the database properties when an instance of Microsoft SQL Server hosts one or more CA Process Automation databases.
Specifies com.microsoft.sqlserver.jdbc.SQLServerDriver as the default driver for MSSQL Server.
Specifies the host where the MSSQL Server is running.
Specifies the default MSSQL Server port, typically 1433.
Specifies the default user name for the MSSQL Server database user.
10 to 512
Default: 10
Specifies the MSSQL database name.
Specifies the MSSQL instance name.
Specifies the database properties when an instance of a MySQL database server hosts one or more CA Process Automation databases.
Specifies com.mysql.jdbc.Driver as the default driver for MySQL.
Specifies the host where the MySQL database is running.
Specifies the default MySQL database port.
Specifies the default user name for the MySQL database user.
10 to 512
Default: 10
Specifies the MySQL database name.
Specifies the database properties when an instance of a Sybase database server hosts one or more CA Process Automation databases.
Specifies the default Sybase relational database system.
Specifies the default connection protocol.
Default: TDS
Specifies the default driver.
Default: com.sybase.jdbc2.jdbc.SybDriver
Specifies the host where the Sybase database is running.
Specifies the default port for the Sybase database.
Specifies the default user name for the Sybase database user.
10 to 512
Default: 10
Specifies the amount of memory that the driver uses to cache insensitive result set data.
Default: -1
Specifies the default batch performance work-around.
Copyright © 2014 CA.
