Previous Topic: Create a Response FileNext Topic: Run or Edit the Silent Install Script File
Required Parameters in the response.varfile
As mentioned previously, an example response file has been provided in the root folder of DVD1. The parameters that are required to perform an unattended installation of CA Process Automation include the following list. Parameters that are not included in this list are optional.
License
thirdPartyLicenseAccepted
licenseAccepted
Install Location
sys.installationDir
Java Location
javaHome
DVD2 Location
domainInstallerDir
Communication Mode
isSecure (true/false)
Database Details
CA EEM Details
New Parameters for CA Process Automation Release 4.2:
nodeCommsV2Port
The port used for simplified communications for the Domain Orchestrator.
eiamSDKLevel
The entry for the CA EEM SDK level.
#hasOracleConnectionString
Specifies whether to provide a connection URL. This is only applicable with Oracle.
#dbOracleConnectionString
JDBC Connection URL.
Example:
jdbc:oracle:thin:@(DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=<database host name>) (PORT=<portnumber>)) (CONNECT_DATA=(SERVICE_NAME=<libDb>))).
Note: The last two entries appear three times; twice for each database. These parameters are only applicable if you select Oracle as your database and you use a connection string.
