Previous Topic: About Agent CommunicationNext Topic: Reinstall or Configure the Current Release
Test Your Processes with Simplified Communication
After you have configured agents to use simplified communication, test your processes again.
  1. Start a process with operators that run on agent touchpoints or on remote hosts through proxy touchpoints. Verify that the process instance completes successfully.
  2. When you are satisfied that agents are working as expected with simplified communications, resume all of your normal processing.
More information:
How to Upgrade CA Process Automation
