Previous Topic: Basic Configuration (Windows)Next Topic: Configure Basic Communication
Install a Load Balancer and Prepare Configuration Templates (Windows)
The CA Process Automation installation media includes the following sample configuration file for the Apache load balancer that you can use as a starting point for configuration:
ApacheConfig.zip
The following instructions assume that an Apache 2.2 load balancer is dedicated to CA Process Automation. First, install an Apache load balancer. Then, extract files from the CA Process Automation ApacheConfTemplates zip file to the Conf folder under the Apache installation folder.
  1. Log in to the host where the load balancer is to run.
    The load balancer typically is not on the same host as your Domain Orchestrator. However, the host with your Domain Orchestrator must be routable from the load balancer.
  2. Download and install the latest Apache load balancer with SSL support. Follow the vendor instructions.
  3. Download the following file for the Apache version that you installed:
    mod_jk.so
    We recommend that you download the latest version.
  4. Copy the mod_jk.so file to the following folder:
    apache_install_dir\modules
  5. Navigate to the following folder on the CA Process Automation installation media:
    install_dir\DVD1\ApacheConfTemplates
  6. Extract the following files from ApacheConfig.zip:
    mod-jk.conf
    httpd-proxy.conf
    uriworkermap.properties
    workers.properties
    httpd VIRTUALHOST_EXAMPLE FILE
    Note: The extracted httpd VIRTUALHOST_EXAMPLE FILE file contains text you can cut and paste into the Apache httpd file when you configure secure communications. The required text is also in the documentation.
  7. Copy the following extracted files to the apache_install_dir\conf folder:
    mod-jk.conf
    httpd-proxy.conf
    workers.properties
    Note: If you do not have an Apache 2.2 load balancer to dedicate, merge the configuration information in the example template properties and Conf files into your existing files. As a precaution, back up your files before you modify them.
