Previous Topic: Get File Information OperatorNext Topic: Output Parameters
Input Parameters
Remote file
Specifies the path for the file on the remote FTP host. For example: "/tmp/IT PAM/scripts/script_ora1.sh"
Remote host
Specifies the IP address or FTP URL for the remote host. For an FTP site on your company intranet, you can specify the server name (//servername) for the FTP site.
By default, FTP sites use port 21. However, you can assign a private port to an FTP site. Private ports range from 49152 to 65535. To specify a private FTP port, add a colon (:) and then a private port number to the end of the address. For example, the following specifies port 50021 on a remote FTP server:
172.24.36.107:50021
Remote user ID
Specifies a user ID to access the remote FTP host.
Remote user password
Specifies the password to access the remote FTP host.
Use secure FTP (SFTP)
Opens a secure FTP (SFTP) session. SFTP is similar to FTP, but unlike FTP, the entire session is encrypted. No passwords are sent in clear text form, so they are much less vulnerable to third-party interception.
Specify an optional SITE command
Specifies to use the SITE command to invoke services that are specific to the host system. Then use the Site parameters field to specify a CA Process Automation expression that returns parameters for the SITE command.
Site parameters
Enter a CA Process Automation expression that returns parameters for the SITE command.
