Previous Topic: Create OperatorNext Topic: Delete Operator
Input Parameters
UCFBrokerURL
Defines the UCF Broker URL of your Catalyst server. Defaults to the UCF Broker URL in the Catalyst configuration.
Specify the Broker URL of the Catalyst Broker Service as:
http://<hostname>:7000/ucf/BrokerService
When using secure Catalyst communications, specify the secure broker URL as:
https://<hostname>:7443/ucf/BrokerService
MdrProduct
Unique identifier of the connecting product.
MdrProdInstance
Unique identifier of the instance of the connecting product as registered in the UCF Broker. CA Process Automation queries the UCF Broker for the list of connectors available and populate this field. You can then select your connector from the drop-down list.
Create
Indicates whether the operator:
Itemtype
Specifies the USM type of the object that is created or updated.
Values:
Alert, ComputerSystem, Router, Service, and so on.
For example:
itemtype=ComputerSystem
Properties
The operator parameters contain the properties of the USM type.
Customizing the Properties
The Properties form can be customized using the "Product property configuration file name". If the MdrProduct and itemtype values match an entry in the "Product property configuration file name", then the form displays according to the following rules:
