Previous Topic: Switch User InformationNext Topic: Operator Ports
Output Parameters
TelnetUserLoginPrompt
The actual User Login Text Prompt that was read from the Telnet session within the time to wait for prompts. This is the data that was matched against the pattern specified in the User Login Text Prompt field.
TelnetUserPasswordPrompt
The actual User Password Text Prompt that was read from the Telnet session within the time to wait for prompts. This is the data that was matched against the pattern specified in the User Password Text Prompt field.
TelnetUserCommandPrompt
The actual User Command Prompt that was read from the Telnet session (within the time to wait for prompts) the first time, either after login or after connection (if no login is required). This is the data that was matched against the pattern specified in the User Command Prompt field.
TelnetSwitchUserPasswordPrompt
The actual Switch User Password Text Prompt that was read from the Telnet session within the time to wait for prompts. This is the data that was matched against the pattern specified in the Switch User Password Text Prompt field.
This field is empty if switching the user did not require a password; for example, when switching from Root to any other user, or if the operator is not set up to switch users.
TelnetSwitchUserCommandPrompt
The actual Switch User Command Prompt that was read from the Telnet session (within the time to wait for prompts) the first time after switching to the new user. This is the data that was matched against the pattern specified in the Switch User Command Prompt field. This field is empty if the operator is not set up to switch users.
TelnetCommandsOutput
An indexed String containing the output read from each command (within the time to wait for prompts) that ran on the remote host. The output for each command is truncated to the value specified in Commands Output Size limit.
The full output of each command contains the next prompt.
TelnetHost
CommandsAsAnArray
parameters
CommandsArray
isPostToOutVar
PostToOutVarSizeLimit
TelnetPseudoTerminalType
TelnetPort
TelnetHostConnectTimeout
TelnetloginScheme
TelnetHostUserLoginPrompt
TelnetUsername
TelnetHostUserPasswordPrompt
TelnetPassword
TelnetHostUserCommandPrompt
TelnetHostWaitTimeout
TelnetSwitchUser
TelnetHostSwitchUserCommand
TelnetHostSwitchUserPasswordPrompt
TelnetHostSwitchUserCommandPrompt
