Previous Topic: The Start OperatorNext Topic: Logical Operators
Add Operators to a Process
After you place the Start operator in a process, drag the next operator, and then join the links that determine the process flow.
  1. Do one of the following to open a process
    1. In the Library Browser, double-click a Process object.
    2. In the Designer toolbar, click Open.
    The Process Designer tab appears. If not already checked out, click Check Out.
  2. Drag an operator from the Operators palette onto the process layout anywhere below or to the right of the Start operator. Operators are arranged in folders for each module or operator category supported by CA Process Automation. Enter the name of an operator in the Search field to search for matching operators.
  3. Repeat the previous step as often as necessary to create a chain of operators.
  4. Create the first link in the chain. Click the small exit port under the Start operator and drag the link to the destination operator's entry port.
  5. Continue to logically connect exit ports to the entry ports of operators in sequence.
  6. Configure each operator by double-clicking it to open its Property palette.
