Previous Topic: Stop an AgentNext Topic: Configure Agents to Use Simplified Communication
About Agent Communication
You configure agent communications when you install an agent. You can reconfigure this setting without reinstalling the agent.
The simplified communication uses web sockets and HTTP to produce a one way, persistent connection from the agent to the Orchestrator. CA Process Automation uses a standard port (80 or 443) that provides a fast connection between the components.
Deprecated Communication
The deprecated communication, which uses multiple ports, is not as firewall-friendly or NAT router-friendly as simplified communication. The Orchestrator-initiated connections used in deprecated communication is not as efficient as the persistent connections used in simplified communication.
Note: For recommendations on load balancers and the corresponding agent communication, see "Load Balancers and Communication" in the Installation Guide.
