RESTful API Reference › RESTful Web Services and CA Process Automation › Catalyst REST › Content REST Examples › Encrypted XML Files
Encrypted XML Files
The Catalyst Import and Export web service methods support encrypted XML files. An XML file that is exported from CA Process Automation is encrypted if it contains any object with a nonmodifiable Release Version attribute.
- You can import a clear or an encrypted XML file.
- You can export a clear or an encrypted XML file. If CA Process Automation detects that the Release Version of one of the exported files is locked, it encrypts the entire XML file. If CA Process Automation detects that the Release Versions of all of the exported files are unlocked, it exports the XML file unencrypted.
Copyright © 2014 CA.
