To update dataset parameters using REST, specify the name of the parameter from the QueryDatasetParameters response. You can use expressions in the value.
For example, send an HTTP POST request to:
http://<hostname>:7000/node/rest/CA:00074_CA:00074:01/_ops/UpdateDatasetParameters
Include a request header:
Content-Type=application/xml
For example:
<UpdateDatasetParametersRequest xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="p1:UpdateDatasetParametersRequest" xmlns:p1="http://ns.ca.com/2011/09/pam-ops" > <Dataset> <PathName>/TestDatasets/TestDataset</PathName> <Parameters> <Param> <Name>Datasets["/TestDatasets/TestDataset"].Zipcode</Name> <Value>Datasets["/TestDatasets/TestDataset"].Zipcode + 100</Value> <Type>Integer</Type> </Param> </Parameters> </Dataset> </UpdateDatasetParametersRequest>
The response contains the updated dataset:
<?xml version="1.0" encoding="UTF-8"?>
<pam-ops:UpdateDatasetParametersResponse
xmlns:pam-ops="http://ns.ca.com/2011/09/pam-ops"
xsi:type="pam-ops:UpdateDatasetParametersResponse">
<Dataset>
<Parameters>
<Param>
<Name>Datasets["/TestDatasets/TestDataset"].Name</Name>
<Value>Harry Truman</Value>
<Label>Name</Label>
<Type>String</Type>
</Param>
<Param>
<Name>Datasets["/TestDatasets/TestDataset"].Address</Name>
<Value>1400 Pennsylvania Avenue</Value>
<Label>Address</Label>
<Type>String</Type>
</Param>
<Param>
<Name>Datasets["/TestDatasets/TestDataset"].City</Name>
<Value>DC</Value>
<Label>City</Label>
<Type>String</Type>
</Param>
<Param>
<Value>2300</Value>
<Label>Zipcode</Label>
</Param>
Note: Before updating a global dataset, make sure that the dataset has been checked in at least once.
Copyright © 2014 CA.
