To query for module names, use the QueryModuleConfigs function.
For example, send an HTTP POST request to:
http://<hostname>:7000/node/rest/CA:00074_CA:00074:01/_ops/QueryModuleConfigs
Include a request header:
Content-Type=application/xml
The following example returns all the modules:
<QueryModuleConfigsRequest xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="p1:QueryModuleConfigsRequest"
xmlns:p1="http://ns.ca.com/2011/09/pam-ops" >
<ModuleName xsi:nil="true"/>
(Optional) <ModuleType>ALL</ModuleType>
</QueryModuleConfigsRequest>
The following example returns the custom modules:
(Optional) <ModuleType>CUSTOM</ModuleType>
The response contains the module names:
<?xml version="1.0" encoding="utf-8"?>
<pam-ops:QueryModuleConfigsResponse
xmlns:pam-ops="http://ns.ca.com/2011/09/pam-ops"
xsi:type="pam-ops:QueryModuleConfigsResponse">
<Module>
<ModuleName>FTPServices</ModuleName>
<Name>File Transfer</Name>
<DisplayName>File Transfer</DisplayName>
<Description>Provides file transfer operations (FTP/SFTP).</Description>
</Module>
<Module>
<ModuleName>WorkflowServices</ModuleName>
<Name>Process Control</Name>
<DisplayName>Process Control</DisplayName>
<Description>Runs, monitors and controls CA Process Automation Processes.</Description>
</Module>
<Module>
<ModuleName>UtilitiesGroup</ModuleName>
<Name>Utilities</Name>
<DisplayName>Utilities</DisplayName>
<Description>This module consists of utility operators which are used in PAM processes</Description>
</Module>
<Module>
<ModuleName>SOAP Services</ModuleName>
<Name>Web Services</Name>
<DisplayName>Web Services</DisplayName>
<Description>Provides an interface to external services exposed through SOAP.</Description>
</Module>
<Module>
<ModuleName>JMX.Group.Name</ModuleName>
<Name>Java Management</Name>
<DisplayName>Java Management</DisplayName>
<Description>Provides a management interface to external system that support JMX.</Description>
</Module>
<Module>
<ModuleName>Process Services</ModuleName>
<Name>Command Execution</Name>
<DisplayName>Command Execution</DisplayName>
<Description>Runs programs and scripts on host operating environments.</Description>
</Module>
<Module>
<ModuleName>Date Time Services</ModuleName>
<Name>Date-Time</Name>
<DisplayName>Date-Time</DisplayName>
<Description>Executes time and calendar constraints in CA Process Automation processes.</Description>
</Module>
<Module>
<ModuleName>FileService</ModuleName>
<Name>File Management</Name>
<DisplayName>File Management</DisplayName>
<Description>This module monitors directory, files, and their contents</Description>
</Module>
Copyright © 2014 CA.
