This function searches the path that you specify between the <PathName> and </PathName> tags in the request for dataset parameters.
For example, send an HTTP POST request to:
http://<hostname>:7000/node/rest/CA:00074_CA:00074:01/_ops/QueryDatasetParameters
Include a request header:
Content-Type=application/xml
For example:
<QueryDatasetParametersRequest xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="p1:QueryDatasetParametersRequest"
xmlns:p1="http://ns.ca.com/2011/09/pam-ops" >
<PathName>/TestDatasets/TestDataset</PathName>
</QueryDatasetParametersRequest>
The response contains the dataset parameters, including their JavaScript names:
<pam-ops:QueryDatasetParametersResponse
xmlns:pam-ops=http://ns.ca.com/2011/09/pam-ops
xsi:type="pam-ops:QueryDatasetParametersResponse">
<Dataset>
<Parameters>
<Param>
<Name>Datasets["/TestDatasets/TestDataset"].Name</Name>
<Value>John Doe</Value>
<Label>Name</Label>
<Type>String</Type>
</Param>
<Param>
<Name>Datasets["/TestDatasets/TestDataset"].Address</Name>
<Value>1400 Any Avenue</Value>
<Label>Address</Label>
<Type>String</Type>
</Param>
<Param>
<Name>Datasets["/TestDatasets/TestDataset"].City</Name>
<Value>DC</Value>
<Label>City</Label>
<Type>String</Type>
</Param>
<Param>
<Name>Datasets["/TestDatasets/TestDataset"].Zipcode</Name>
<Value>00000</Value>
<Label>Zipcode</Label>
<Type>Integer</Type>
</Param>
<Param>
<Name>Datasets["/TestDatasets/TestDataset"].VMap.VarString</Name>
<Value>updated1</Value>
<Label>VarString</Label>
<Type>String</Type>
</Param>
<Param>
<Name>Datasets["/TestDatasets/TestDataset"].VMap.VarDate</Name>
<Value xsi:nil="true"/>
<Label>VarDate</Label>
<Type>Date</Type>
</Param>
<Param>
</Parameters>
</Dataset>
</pam-ops:QueryDatasetParametersResponse>
Copyright © 2014 CA.
