You can import a local file of CA Process Automation objects.
For example, send an HTTP POST request to:
http://<hostname>:7000/node/rest/CA:00074_CA:00074:01/_ops/Import
Include a request header:
Content-Type=application/xml
For example:
<ImportRequest xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="p1:ImportRequest"
xmlns:p1="http://ns.ca.com/2011/09/pam-ops" >
<ImportLocation>/TestContent/</ImportLocation>
<SourceLocation>C:\Program Files\CA\PAM40\standalone\.c2orepository\public\content\ITPAMContent.xml</SourceLocation>
<OverwriteAction>ImportAndReplace</OverwriteAction>
<SetCurrent>true</SetCurrent>
</ImportRequest>
If the library already contains an object with the specified name, set <OverwriteAction> to one of the following options:
Increase the version of the imported object if an object of the same exists in the specified import folder. Overrides the release version if the same release version exists.
Do not import objects with the same name as an existing object.
Import and replace the existing object. It deletes the previous versions of the object.
The response indicates whether the import was successful:
<?xml version="1.0" encoding="utf-8"?>
<pam-ops:ImportResponse xmlns:pam-ops="http://ns.ca.com/2011/09/pam-ops"
xsi:type="pam-ops:ImportResponse">
<SuccessMessage>The specified object imported successfully.</SuccessMessage>
</pam-ops:ImportResponse>
Copyright © 2014 CA.
