You can display any specific object in a browser using these URL formats:
http://<hostname>:7000/node/rest/CA:00074_CA:00074:01/<type>/<id>
http://<hostname>:7000/node/rest/CA:00074_CA:00074:01/<type>?id=<id>
Where:
For example, use the following URL to display a process instance (ITActivity) with id of "TestSubscribeAlert_59":
http://<hostname>:7000/node/rest/CA:00074_CA:00074:01/ITActivity/TestSubscribeAlert_59
http://<hostname>:7000/node/rest/CA:00074_CA:00074:01/ITActivity?id=TestSubscribeAlert_59
By refreshing the browser, you can monitor the process instance status (in the ActivityState or StateDescription properties of the ITActivity).
<?xml version="1.0" encoding="utf-8"?> <usm-core:ITActivity xmlns:usm-core="http://ns.ca.com/2009/07/usm-core"> <usm-core:MdrProduct>CA:00074</usm-core:MdrProduct> <usm-core:MdrProdInstance>CA:00074:01</usm-core:MdrProdInstance> <usm-core:MdrElementID>TestSubscribeAlert_59</usm-core:MdrElementID> <usm-core:Label>Workflow:TestSubscribeAlert_59:59:59</usm-core:Label> <usm-core:CreationTimestamp>2012-04-18T15:57:38</usm-core:CreationTimestamp> <usm-core:LastModTimestamp>2012-04-18T15:59:18</usm-core:LastModTimestamp> <usm-core:LastModUserName>pamadmin</usm-core:LastModUserName> <usm-core:InstanceName>TestSubscribeAlert_59:59:Workflow</usm-core:InstanceName> <usm-core:ActivityID>59</usm-core:ActivityID> <usm-core:RuntimeName>TestSubscribeAlert_59</usm-core:RuntimeName> <usm-core:RuntimeDiscriminator>59</usm-core:RuntimeDiscriminator> <usm-core:ActivityTypes>Workflow</usm-core:ActivityTypes> <usm-core:ActivityState>Finished-Completed</usm-core:ActivityState> <usm-core:StateDescription>Completed</usm-core:StateDescription> <link xmlns="http://ns.ca.com/2010/11/coreapi" href="http://mulwi01-w500:7000/node/rest/CA:00074_CA:00074:01/ITActivity/TestSubscribeAlert_59" rel="self"/> </usm-core:ITActivity>
Copyright © 2014 CA.
