Use this method to obtain CA Process Automation version details.
<tns:getITPamVersion xmlns:tns="http://www.ca.com/itpam"> <tns:auth> <!--xsd:Choice Type--> <tns:token>token__</tns:token> <tns:user>Joe</tns:user> <tns:password>thisismypassword</tns:password> <tns:auth> </tns:getITPamVersion>
<?xml version="1.0" encoding="UTF-8"?> <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <SOAP-ENV:Header/> <SOAP-ENV:Body> <tns:getITPamVersion xmlns:tns="http://www.ca.com/itpam"> <tns:auth> <tns:user>Joe</tns:user> <tns:password>thisismypassword</tns:password> <tns:auth> </tns:getITPamVersion> </SOAP-ENV:Body> </SOAP-ENV:Envelope>
<servicePack> identifies the current CA Process Automation service pack (optional).
<patchNumber> identifies the current CA Process Automation patch number (optional).
<buildDetails> identifies any build details being used with the current CA Process Automation version (optional).
<majorVersion> identifies the current CA Process Automation version.
<minorVersion> identifies the current CA Process Automation minor version.
<buildNumber> identifies the current CA Process Automation build number.
<buildDate> identifies the current CA Process Automation build date.
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"> <SOAP-ENV:Header/> <SOAP-ENV:Body> <ITPamVersionDetails xmlns="http://www.ca.com/itpam"> <majorVersion>4</majorVersion> <minorVersion>0</minorVersion> <patchNumber>0</patchNumber> <buildNumber>335</buildNumber> <buildDate>2012-03-01T06:08:09.000+05:30</buildDate> </ITPamVersionDetails> </SOAP-ENV:Body> </SOAP-ENV:Envelope>
<buildDetails> provides additional details about the build (optional).
Copyright © 2014 CA.
