Use this method to export a library using a Web service call.
Note: Ensure that the maximum XML size that you want to export is 250 MB.
<tns:exportObject xmlns:tns="http://www.ca.com/itpam"> <tns:auth> <!--xsd:Choice Type--> <tns:token>token__</tns:token> <tns:user>Joe</tns:user> <tns:password>thisismypassword</tns:password> <tns:auth> <tns:folderName>/SOAPTest/ObjectsToExport</tns:folderName> <tns:level>2</tns:level> <tns:isAbsolute>true</tns:isAbsolute> <tns:downloadFileName> <tns:downloadLocation>C:\</tns:downloadLocation> <tns:fileName>SOAPExportedObjects.xml</tns:fileName> <tns:overwriteFile>true</tns:overwriteFile> </tns:downloadFileName> <tns:filter> <tns:exportObjectTypes> <tns:objectType>Agenda</tns:objectType> <tns:objectType>Calendar</tns:objectType> <tns:objectType>CustomIcon</tns:objectType> <tns:objectType>CustomOperator</tns:objectType> <tns:objectType>Dataset</tns:objectType> <tns:objectType>InteractionRequestForm</tns:objectType> <tns:objectType>Package</tns:objectType> <tns:objectType>Process</tns:objectType> <tns:objectType>ProcessWatch</tns:objectType> <tns:objectType>Resources</tns:objectType> <tns:objectType>StartRequestForm</tns:objectType> </tns:exportObjectTypes> </tns:filter> </tns:exportObject>
The request contains:
Note: All parameters are optional with the exception of FolderName.
<?xml version="1.0" encoding="UTF-8"?> <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <SOAP-ENV:Header/> <SOAP-ENV:Body> <tns:exportObject xmlns:tns="http://www.ca.com/itpam"> <tns:auth> <tns:user>Joe</tns:user> <tns:password>thisismypassword</tns:password> <tns:auth> <tns:folderName>/SOAPTest/ObjectsToExport</tns:folderName> <tns:level>2</tns:level> <tns:isAbsolute>true</tns:isAbsolute> <tns:downloadFileName> <tns:downloadLocation>C:\</tns:downloadLocation> <tns:fileName>SOAPExportedObjects.xml</tns:fileName> <tns:overwriteFile>true</tns:overwriteFile> </tns:downloadFileName> <tns:filter> <tns:exportObjectTypes> <tns:objectType>Agenda</tns:objectType> <tns:objectType>Calendar</tns:objectType> <tns:objectType>CustomIcon</tns:objectType> <tns:objectType>CustomOperator</tns:objectType> <tns:objectType>CustomSensor</tns:objectType> <tns:objectType>Dataset</tns:objectType> <tns:objectType>InteractionRequestForm</tns:objectType> <tns:objectType>Package</tns:objectType> <tns:objectType>Process</tns:objectType> <tns:objectType>ProcessWatch</tns:objectType> <tns:objectType>Resources</tns:objectType> <tns:objectType>StartRequestForm</tns:objectType> <tns:objectType>StatePolicy</tns:objectType> <tns:objectType>System</tns:objectType> </tns:exportObjectTypes> </tns:filter> </tns:exportObject> </SOAP-ENV:Body> </SOAP-ENV:Envelope>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"> <SOAP-ENV:Header/> <SOAP-ENV:Body> <ExportLibraryResponse xmlns="http://www.ca.com/itpam"> <exportLibraryResponse>Successfully uploaded the exported library to provided download file name:C:\SOAPExportedObjects.xml</exportLibraryResponse> <downloadedServer>PAM40-W2K8-17</downloadedServer> </ExportLibraryResponse> </SOAP-ENV:Body> </SOAP-ENV:Envelope>
Copyright © 2014 CA.
