Use this method to search the start request forms in a CA Process Automation library. A search is based on the path and keyword provided.
<tns:getStartRequestForms xmlns:tns="http://www.ca.com/itpam"> <tns:auth> <!--xsd:Choice Type--> <tns:token>token__</tns:token> <tns:user>Joe</tns:user> <tns:password>thisismypassword</tns:password> <tns:auth> <tns:filter> <tns:lookUpPath isRecursive="true">/</tns:lookUpPath> <tns:keywords> <tns:keyword>ABC</tns:keyword> </tns:keywords> </tns:filter> </tns:getStartRequestForms>
Provide / and remove the Keyword__ from the Keyword tags:
<tns:getStartRequestFormsResponse xmlns:tns="http://www.ca.com/itpam"> <startRequests> <tns:startRequest name="Start Purchase Request Form" refPath="/PAM Hardware Procurement/"> <tns:description/> </tns:startRequest> <tns:startRequest name="Asset_Install_SW_SRF" refPath="/sinra1/CA ITAM/SRF/"> <tns:description>Database Object</tns:description> </tns:startRequest> <tns:startRequest name="Asset_MAC_HW_SRF" refPath="/sinra1/CA ITAM/SRF/"> <tns:description>Database Object</tns:description> </tns:startRequest> <tns:startRequest name="Asset_Transfer_SRF" refPath="/sinra1/CA ITAM/SRF/"> <tns:description>Database Object</tns:description> </tns:startRequest> <tns:startRequest name="Asset_Disposal_HW_SRF" refPath="/sinra1/CA ITAM/SRF/"> <tns:description>Database Object</tns:description> </tns:startRequest> <tns:startRequest name="Asset_Install_HW_Transferred_SRF" refPath="/sinra1/CA ITAM/SRF/"> <tns:description>Database Object</tns:description> </tns:startRequest> <tns:startRequest name="Asset_Install_HW_SRF" refPath="/sinra1/CA ITAM/SRF/"> <tns:description>Database Object</tns:description> </startRequest> <tns:startRequest name="~Start Request Form" refPath="/Package Demo/"> <tns:description/> </tns:startRequest> <tns:startRequest name="~Start Request Form" refPath="/Jack/"> <tns:description/> </tns:startRequest> </tns:startRequests> </tns:getStartRequestFormsResponse>
You can search start request forms with keywords that are associated with them. For example, you can perform a search to find if SRF1 and SRF2 are associated with the keyword "ABC" in the folder /myfolder.
<tns:getStartRequestForms xmlns:tns="http://www.ca.com/itpam"> <tns:auth> <tns:user>Joe</tns:user> <tns:password>thisismypassword</tns:password> <tns:auth> <tns:filter> <tns:lookUpPath isRecursive="true">/myfolder</tns:lookUpPath> <tns:keywords> <tns:keyword>ABC</tns:keyword> </tns:keywords> </tns:filter> </tns:getStartRequestForms>
<?xml version="1.0" encoding="UTF-8"?> <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"> <SOAP-ENV:Header/> <SOAP-ENV:Body> <tns:getStartRequestForms xmlns:tns="http://www.ca.com/itpam"> <tns:auth> <tns:user>Joe</tns:user> <tns:password>thisismypassword</tns:password> <tns:auth> <tns:filter> <tns:lookUpPath isRecursive="true">/</tns:lookUpPath> <tns:keywords> <tns:keyword>ABC</tns:keyword> </tns:keywords> </tns:filter> </tns:getStartRequestForms> </SOAP-ENV:Body> </SOAP-ENV:Envelope>
This tag is present in the <filter> tag:
<getStartRequestFormsResponse xmlns="http://www.ca.com/itpam"> <startRequests> <startRequest name="SRF1" refPath="/TENSU03/"> <description/> </startRequest> <startRequest name="SRF2" refPath="/TENSU03/"> <description/> </startRequest> </startRequests> </getStartRequestFormsResponse>
For every start request form that fulfills the criteria for the search, there is a <startRequest> under the <startRequests> tag. This tag contains the name, reference path, and description of the start request form in the SOAP response.
Copyright © 2014 CA.
