Use this method to create a request to control a process.
<tns:controlProcess xmlns:tns="http://www.ca.com/itpam"> <tns:ProcessID>ProcessID__</tns:ProcessID> <tns:action>action__</tns:action> <tns:auth> <!--xsd:Choice Type--> <tns:token>token__</tns:token> <tns:user>user__</tns:user> <tns:password>password__</tns:password> </tns:auth> </tns:controlProcess>
<?xml version="1.0" encoding="UTF-8"?><SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<SOAP-ENV:Header/>
<SOAP-ENV:Body>
<tns:controlProcess xmlns:tns="http://www.ca.com/itpam"> <tns:ProcessID>47</tns:ProcessID> <tns:action>suspend</tns:action> <tns:auth> <!--xsd:Choice Type--> <tns:token>token__</tns:token> <tns:user>Joe</tns:user> <tns:password>thisismypassword</tns:password> <tns:auth> </tns:controlProcess></SOAP-ENV:Body></SOAP-ENV:Envelope>
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"> <SOAP-ENV:Header/> <SOAP-ENV:Body> <controlProcessResponse xmlns="http://www.ca.com/itpam"> <actionStatus>The suspend action for Process ID "47" was queued.</actionStatus> </controlProcessResponse> </SOAP-ENV:Body> </SOAP-ENV:Envelope>
You can suspend a single process instance through a web services method.
If you cannot suspend a process instance (for example, it already completed or aborted), an error message returns containing details about the request.
Here is an example of a fault when you try to suspend a completed process:
<Fault xmlns="http://schemas.xmlsoap.org/soap/envelope/"> <faultcode>SOAP-ENV:Server</faultcode> <faultstring>The process with Process ID "208" is in completed state and therefore cannot be suspended.</faultstring> </Fault>
You can resume a single process instance that was previously suspended through a web services method.
If you cannot resume a process instance, an error message returns containing details about the request. For example, a process instance cannot resume because it was already completed, aborted, or not currently suspended.
Here is an example of a fault when you try to resume a completed process:
<Fault xmlns="http://schemas.xmlsoap.org/soap/envelope/"> <faultcode>SOAP-ENV:Server</faultcode> <faultstring>The process with Process ID "208" is in completed state and therefore cannot be resumed.</faultstring> </Fault>
You can abort a single process instance through a web services method.
If you cannot abort a process instance (for example, it already completed or aborted), an error message returns containing details about the request.
Here is an example of a fault when you try to abort a completed process:
<Fault xmlns="http://schemas.xmlsoap.org/soap/envelope/"> <faultcode>SOAP-ENV:Server</faultcode> <faultstring>The process with Process ID "486" is in completed state and therefore cannot be Aborted.</faultstring> </Fault>
<tns:ProcessID>ProcessID </tns:ProcessID>
<tns:action>action</tns:action>
<tns:auth>
<tns:auth></tns:controlProcess>
"ProcessedID" is the ROID of the process instance that you must control (suspend/ resume/abort). The "ROID" of a running process is in the response when executing a process through web services.
<tns:ExecuteC2OFlowResponse xmlns:tns="http://www.ca.com/itpam"> <tns:ExecuteC2OFlowResult> <tns:ROID>567</tns:ROID> ... ... </tns:ExecuteC2OFlowResult> </tns:ExecuteC2OFlowResponse>
The value for action is to suspend, resume, or abort. Only an authorized user can perform this action; otherwise, a fault is returned.
<SOAP-ENV:Fault xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"> <faultcode>SOAP-ENV:Server</faultcode> <faultstring>Invalid user/password or token.</faultstring> </SOAP-ENV:Fault>
A fault returns if you try to perform an operation that you cannot perform on a process in its current state. For example, trying to suspend a process that already completed.
<SOAP-ENV:Fault xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/"> <faultcode>SOAP-ENV:Server</faultcode> <faultstring>Process with Process Id "576" is in completed state therefore cannot be suspended.</faultstring> </SOAP-ENV:Fault>
Copyright © 2014 CA.
