Previous Topic: Input ParametersNext Topic: Example
Output Parameters
@FileName
The full path for the file as calculated from the "File Name" expression.
FileExists
1 if a file exists, 0 if it does not exist.
FileName
FileTime
Specifies the file time.
FileDate
Specifies a file date.
IsDirectory
1 if describing a directory, 0 if not describing a directory.
IsFile
1 if describing a file, 0 if not describing a file.
IsLink
1 if the item is a symbolic link in UNIX, 0 otherwise.
FileOtherRead
FileOtherWrite
FilePermission
FileSize
The size of the file in bytes.
FileSizeKB
The size of the file in kilobytes (KB = 1,024 bytes). A fraction of a kilobyte is counted as one kilobyte.
FileSizeMB
The size of the file in megabytes (MB = 1,024 KB). A fraction of a megabyte is counted as one megabyte.
FileGroup
FileOwner
FileGroupExec
1 if the group can execute, 0 if the group cannot execute.
FileGroupRead
1 if the group can read, 0 if the group cannot read.
FileGroupWrite
1 if the group can write, 0 if the group cannot write.
FileOtherExec
1 if others can execute, 0 if other cannot execute.
FileOwnerExec
1 if the owner can execute, 0 if the owner cannot execute.
FileOwnerRead
1 if the owner can read, 0 if the owner cannot read.
FileOwnerWrite
1 if the owner can write, 0 if the owner cannot write.
IsSpecial
1 if a special system file, 0 if not a special system file.
Note: The definition of a special system file is platform-dependent.
