Previous Topic: TFTP Download File OperatorNext Topic: Output Parameters
Input Parameters
Remote Hostname
The host name or the IP address of the remote host.
Remote UDP Port for TFTP
The UDP port of the TFTP service on the remote host. If this parameter is specified, this value overrides the value of the operator category field: Default UDP Port for Trivial FTP. If none of these fields are specified, the operator uses the default value of 69.
Remote File name
The name of the remote file to obtain from the remote host. This parameter is not the path of the remote file on the remote host. Depending on its setup, the TFTP server retrieves the file from its base directory in the remote host.
Data Transfer Type
BIN for binary or ASCII for ASCII (text). If this type is not specified, the operator uses the default value: ASCII. If any other value is specified (other than ASCII or BIN), the operator uses the default value of ASCII.
Local File to Download
The fully qualified path of the local file (where you save the file retrieved through TFTP).
Local Port Number (0 for anonymous port)
The local port number to use when retrieving data from the remote host/port. If 0, an anonymous port is used. If the port is specified and the port is unavailable, the operation could fail. If this number is not specified, the operator uses the default value: 0.
Timeout (sec)
The timeout value to use when opening the connection to the TFTP server. If this number is not specified, the value defaults to 20.
Maximum Retries after TFTP Timeout
The maximum number of times to retry the download file operation (not the entire CA Process Automation operator) after a TFTP timeout. If this number is not specified, the operator uses the default value: 5.
