Previous Topic: Get Directory Content OperatorNext Topic: Output Parameters
Input Parameters
Base directory
Specifies the path for the directory in which to start the search.
File path/name mask
Specifies the pattern that the operator detected.
Case sensitive pattern matching
When checked, matches upper-case and lower-case characters when searching for a pattern. If unchecked, the letters in a pattern match both upper and lower-case characters.
Sort items by last modification time
When checked, sorts the folders or files within a specified directory by the last modification time.
Match pattern on file/directory name
When checked, matches only file or directory names, instead of anywhere in a path.
Directories included in results
Select from one of the following options:
Recursion level
The number of directory levels to go down to when matching files or directories.
State timer (secs)
The minimum interval for which the condition must be maintained.
