Previous Topic: Compress File OperatorNext Topic: Output Parameters
Input Parameters
Source File/Directory Name
Specifies the name of file or directory to be compressed.
Notes: On the Windows host, the compressed file extension is ".zip".
On a UNIX host, if the source is a directory, then every file under that directory is compressed and is replaced one with the extension ".gz".
Working Directory
Specifies the working directory to execute this operation.
Notes: If the working directory is not specified, the user's home directory will be the working directory.
The file path can be absolute or relative to the working directory.
User ID
Specifies the user account to be used while executing the operator on the host. Overrides the user specified in the operator category level properties.
Password
Specifies the password for the user.
