Previous Topic: ValueMap Data TypeNext Topic: Array and Object Access Operators
JavaScript Operators
You can use JavaScript operators to build string, integer, Boolean, and logical expressions from a combination of entities (integers, strings, functions, and datasets). The number of operands that they expect characterizes JavaScript operators. Most JavaScript operators are binary operators that combine two expressions into one more complex expression.
JavaScript also supports several unary operators that convert a single expression into one more complex expression. This section discusses the JavaScript operators that are most commonly used in CA Process Automation expressions.
