Previous Topic: Perform an ImportNext Topic: Values Maintained in the Initial Version of a Copied Object
Release Version and Baseline Status of Imported Objects
The state of the Release Version attribute (modifiable or nonmodifiable) and the Baseline status of each imported object depend on the following conditions:
The following import options are available for handling existing objects for which the import is a new version:
Case 1: The imported versions are the only versions of the objects in the import environment.
The imported version is the only version of the object in the following situations:
Consider the properties of an object that you create. Version 0 of the object is marked as current, is not baselined, and has a modifiable Release Version attribute.
Set Release Version option on the Versions tab.
The following illustration summarizes the cases:
The new object has Release Versions set as defined in the XML file. If the Release Version attribute is nonmodifiable, then the version is baselilned.
Case 2: The imported versions are the new versions of existing objects in the import environment.
Consider the case where you import a new version of an existing object, where the Release Version attribute of the existing object is nonmodifiable.
Consider the case where you import a new version of an existing object, where the Release Version attribute of the existing object is modifiable.
The following illustration summarizes these cases:
Locked versions stay locked; if XML is nonmodifiable Existing Versions become nonmodifiable.
